ATTENTION! Z31/Altima Rotor Rear Brake Owners!
LoserCard
Car: Forest Green 1993 240SX SE Fastback
SOLVED! Z31 Caliper Bracket Upgrade!
All the info you will need... Brought to you by COCARO-Racing.com :dblthumb:
Marcinko
Car: 240sx
I personally worry about redrilling rotors... the holes are pretty close it looks like. Maybe it's just my paranoia.
It would be kind of a pain to have to redrill rotors every time the old ones wore out.
Good work on being proactive about a solution though.
Arqi
I've been reading through several threads regarding this upgrade. But I can't find info or any mention about using/testing the non vented z31 rotors with the 84-86 bracket. Will those rotors not fit?
LoserCard
It Will Be Too small, This Whole Thread Has Been Focused On Finding A Large Enough Rotor To Use With The 84-86 Bracket. The Non Vented Z31 Rotor Is 290Mm so Essentially It's Worse Than The Altima Rotor (292mm) For This Setup.
(Btw, My Phone Keeps Capitalizing Every Word)
