nhonda5185 »
https://forums.nicoclub.com/nhonda5185-u188959.html
Wed Apr 25, 2012 8:56 pm
t25 turbo
370cc injectors
stock maf
walbro 255
fmic
3 inch dp
emance rom tune
stock fpr
ngk bkr7e plugs
so i finally have everything set up on my kadet. Started it up, idle went way up and then died..i could keep it going though if i pressed on the gas. Well i finally got that fixed after an hour or two of searching for vacuum lines. Before that it seemed to stay on and run ok when the MAF was NOT plugged in. Well i re-sealed the EGR block off and i T'd off the hose that goes from the throttle body to the cold side pipe into the crank case opening. It was running at 800 or so rpm after that with the MAF plugged in so i was pumped. Went out a few hours later and it started right up, The idle was at 800rpm but when i pressed on the gas there was a hesitation and then revved up to 2000 rpm and slowly came down to 1500 and stayed there. my innovative wideband says i am running 11.4 or 11.3 but its not moving from there even when i give it gas?? I do have an aftermarket fpr but do not have it hooked up. could that be the problem??? I have done lots of looking, lots of answers but none for my specific problem...I need help
Thanks a TON
Nate
