Aftermarket stereo w/ Surround View
elight
Car: 2013 Nissan Rogue SV w/ SL package
I recently purchased a 2013 Rogue SV w/ SL package, fully loaded. While I like the car, I have found the stereo to be so lacking that I am already thinking about replacing it. (The navigation is so useless that I will likely never use it again. The audio interface is cumbersome. I really wish there was Bluetooth streaming.)
I know that many aftermarket stereos have support for a back-up camera, but in searching around, I have not found anyone that has the Around View cameras that has tried to go the aftermarket route. Does anyone know if it is possible? Are the controls that switch the camera views part of the factory stereo unit, or does that switching happen before the video signal reaches it (which I would think means that the switching button would still work)?
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
elight wrote:I recently purchased a 2013 Rogue SV w/ SL package, fully loaded. While I like the car, I have found the stereo to be so lacking that I am already thinking about replacing it. (The navigation is so useless that I will likely never use it again. The audio interface is cumbersome. I really wish there was Bluetooth streaming.)
I know that many aftermarket stereos have support for a back-up camera, but in searching around, I have not found anyone that has the Surround View cameras that has tried to go the aftermarket route. Does anyone know if it is possible? Are the controls that switch the camera views part of the factory stereo unit, or does that switching happen before the video signal reaches it (which I would think means that the switching button would still work)?
not possible. the whole nissan system is very proprietary for right now. you will not find an aftermarket radio that can handle the around-view-monitor system. at most you will have is the rear facing camera and thats it. and no guarantee that you wont have to use an aftermarket rear cam on top of it all.
elight
Thanks. I guess I'm stuck with it!
zummuz
Car: Nissan Qashqai
The AVM system has its own module. Also the output of this system is standard video like all other cheap chinese cameras. All you have to do is to double check prior to change with a lcd screen the output of AVM module. Better find an specialist to check for you if electronics is not your best "feature". :chuckle:
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
ImStricken wrote: not possible. the whole nissan system is very proprietary for right now. you will not find an aftermarket radio that can handle the around-view-monitor system. at most you will have is the rear facing camera and thats it. and no guarantee that you wont have to use an aftermarket rear cam on top of it all.
TO: Pioneer Customer Service Department, features and specifications inquiry.
I own a 2012 Nissan Rogue SL with the Around-View Monitor System, which inputs four cameras to one screen. I would like to know if the Pioneer AVH-X8500BHS would be a compatible replacement. More importantly, will it display input from 4 cameras in rear view mode? Thank you for your assistance.
RE: Feature and Specification
Thank you for contacting Pioneer Electronics (USA) Inc.
Our displays only have a composite video input, for one video signal.
I do not know how the factory system outputs the video from their cameras. I would suggest consulting with a professional installer. They will have details on your vehicle and will advise what adapter you may need, if any.
Sincerely,
Rocky
Customer Service Representative
followingnfront
Car: 2017 Maxima S
I think the Bose sound system is awesome in this car!
elight
Thank you Rogue for the information from Pioneer. If anyone does take their car into a professional car stereo installer for a look, I'd love to know what they say. I barely use the stereo at this point. The navigation is completely worthless (I use Google Maps on my Galaxy S3), and the Bluetooth dialing takes so much time to get through all of the menus that I often just dial from the phone. Navigating through my USB thumb drive is usually difficult, as is shuffling all songs inside a folder. Would love to replace this thing.
rdub2k4
Car: 2012 Nissan Rogue SE
2011 Mitsubishi Lancer GTS
If I had the surround view on our Rogue, I would definitely let you know. (former professional installer). Best I can do now is look at wiring diagrams and assume.
I have tapped into the factory rear camera on our S Special Edition, and it works like a charm.
elight
Thanks, rdub. Any insight you have from the wiring diagrams would be greatly appreciated. I would think it's either straightforward - either there's a single wire with a composite camera feeds (meaning a unit external to the stereo stitches them together), or there's four wires with four different feeds.
My guess (and hope) is that it's the former. Since other trim levels have the same exact stereo head unit, it doesn't seem logical that Nissan made a different one capable of taking input from four cameras. Makes much more sense that they would just insert an additional control unit (connected to the "Camera" button that switches the view) external to the head unit.
zummuz
Car: Nissan Qashqai
Your assumptions are correct. All 4 cameras outputs goes to AVM module which multiplex them or select one by one with that "camera button" under the Connect. The AVM module outputs composite video signal like the old rear view camera or even other chinese cameras.
Just look at AV.pdf from FSM to identify the right wires. On 24pins connector on the back of your Connect unit, lower right the last 4 pins are: + video in, GND video in, +6V, GND.
elight
Awesome, thanks for the info. Now I'm going to have to look seriously into replacing this thing. Does anyone have any recommendations for aftermarket head units that work well with the Rogue's various features (the camera, the steering wheel controls, and I supposed the USB/line-in jacks in the center console)?
zummuz
Car: Nissan Qashqai
Just look here:
http://www.nicoclub.com/FSM/Rogue/2011/AV.pdf#page166
This one is just for the old single rear view camera but the inputs are the same.
You can output the AVM module on every monitor that accept composite video in.
You will even have the guiding lines accordingly to the steering wheel when in reverse because all these are made into AVM module.
minibus4
Car: 2008 AWD SL
http://www.sonicelectronix.com/item_228 ... -ASWC.html
^ This is what I used in mine and works without any problems. You can do whatever configuration you want for the the usb and AUX connections. IMO, the more oem/stock you can make the car look, the better.
Plaz
Car: Dualis 2013 ti-l
Hi,
I also am trying to install an aftermarket headunit with my nissan dualis(qashqai)
I have seen the rogue 2013 service manual and it is in fact has a around view module that sends an image to the nissan connect.
The problem is my connector has only 3 wires instead as mentioned above and also in the rogue service manual 4 wires - camera +- and 6v ground
I also tried to run the RCA wires from aftermarket headunit into the two wires - white and black with silver - the other one is 6v.. But still no picture.
Leo2005
zummuz wrote:Just look here:
Do all cameras have rca output like a rear 1? What about replacement avm module with a different one? I would have an idea of combining all cameras (if all have rca) into new module with single rca output. Think about connecting surveillance cameras when you connecting cameras to dvr and then you have only 1 video output in order to make them work with aftermarket unit. You could make them work as surveillance cameras if you install dvr.
ImStricken06
2016 Kia Sorento
Leo2005 wrote:Think about connecting surveillance cameras when you connecting cameras to dvr
yea but that security camera dvr has a MULTIPLEXER
WIKI: An electronic multiplexer makes it possible for several signals to share one device or resource
zummuz
Car: Nissan Qashqai
All cameras have composite video output.
Everybody can check this by connecting to a LCD input.
Plaz
Good News ppl,
Got my after market ouku android rooted system working with my around view module/camera.
So yes it can be done
Only needed 3 wires that are on the right in picture above. (this is for dualis 2013 - Australian model - 2013 rogue service manual was complete different)
The white one is RCA + and the black one is RCA -
The pink one above is the switch for reverse and when you push the camera button so connect your after market switch to that - Its only 5v
That's it...! Can't believe it took me 3 weeks and a blown ECU fuse to find out. Nobody would help - Nissan - Car stereo shops - Internet.
So enjoy and I hope it has saved you time.
http://www.youtube.com/watch?v=A57SEbGwtPg
rdub2k4
very interesting my friend... wish I had the AVM so I could test it here in the states. Good job!
2013 Rogue SV
Car: 2013 Nissan Rogue SV with premium package
So I have the factory camera. But I have an SV. If I add the camera button and tap into the pink wire, could I view the camera at any time by a push of the button?
zummuz
Car: Nissan Qashqai
That camera button is only for AVM. It means 4 cameras connected to a control module. For a single camera it only have to be properly wired (12V, ground and signal) and your unit should know to accept input signal from camera when in reverse.
It's nothing magic, just pure science.
cunninr2
Car: Quashqai +2 2012
Plaz wrote:Good News ppl,
This is awesome. been looking to do the same thing . Do you think you could post the picture again. it is no longer avaialable
MissPretty
Car: Nissan Rogue 2012 SV with Bose
So I hope I can get any help here. I have purchased and had installed an aftermarket unit. However when the guys who installed it got in there, they discovered that they needed a 24-pin adapter to make the AVM/backup camera function, as well as the Steering wheel controls. I would appreciate ANY and all info and how and what piece I need to make this work. I'm sick that I've bought all the pieces and stereo that I thought I would need and now that its installed cannot use the AV camera, backup camera, or steering wheel controls! Anything that could help the store that installed it.. Please help me.. please and thanks!
coolercity
Hi,
Did anyone figure out how to get the surround cameras to work on a aftermarket stereo? Looking to put in top of line pioneer or kenwood radio with backup cam inputs, but wants to keep the surround view functionality. Thanks!
MissPretty
I have steering wheels and backup camera working, however I was told that the remaining cameras will only work with stock and cannot be retained. They tried and were unsuccessful.
Rogue One
2022 Honda Pilot SE
Ok folks listen up. Currently NONE of the aftermarket head units available from name brand manufacturers support the around view system. NONE, NADA, ZIP, ZERO, ZILCH.
There is an after market no-name Chinese unit that apparently will support the multi camera input, and another member has installed it, and it seems to be working fine.
frijolito
Car: Rogue (Xtrail) 2020 Advance
The MXtron Android supports surround view with no issue.
coolercity
But
frijolito wrote:The MXtron Android supports surround view with no issue.
BUt from my understanding the mxtron does not support rogue that came with factory nav (because the harness is different). Do you know if this is true?
frijolito
Very True, its only for Xtrails at the moment, not the US Rogue model with GPS..
frans
Car: QQ 1.6dCI N-Connecta
Anyone tried this product:
10-2-inch-1024-600-touchscreen-2013-2014-2015-nissan-qashqai-gps-radio-navigation-system-with-bluetooth-music-digital-tv-odb2-dvr-backup-camera-mirror-link-tpms-steering-wheel-control-s301074
from seicane com
(can't seem to post the direct url so just google it..)
They claim in the Q&A that 360° also work...
Return to “Rogue Forum”
