maxnix wrote:There was an OEM conversion kit at one time, and it included new evaporator, new condenser, and I think a different compressor. Due to all the labor (not to mention the parts cost), they probably only sold less than ten of them. Remember, true or not, the 1994+ grill was alledgedly installed to get more air to the coils so the less efficient R134a worked better.
There is a lot of detail in Q45tech's early posts. Ignore them at your car's peril!
Thus, is is generally better to maintain an R12 system by mechanically replacing the lubricating fluid, R12 and dyer periodically for a couple of hundred than spending thousands to convert to R134a. Q45tech has posted several times on this topic and how this is properly accomplished.
While the release of any flouride gas is not good, and thus illegal, the effects of R12 vs. R134a are not totally understood on the long term. Nevertheless, running a combustible gas as a substitution for either will hopefully be avoided by our members for obvious reasons.
Yawn....
Do some research other than searching under "Q45tech".... Understand that at $200, I really don't care if it only last for 5 years. I will still be making out like a bandit. Any futher work I do will be less the cost of an evaporator and flush so that cuts the $ number more than half.
R12 is a hassle and that hassle increases exponentially as years pass. I actually started out trying to convert to Freeze12 which is the most available R12 substitute. Heard stories of smokers igniting while running
AC from which R12 was leaking from evaporator directly in the cabin or while performing DIY. Safest and most legal gas to work with DIY = R134 . You can vent it into the air if you want which would land you in the clinker with R12!
Doing a little research will show that it's suggested to stick with R12 if your system is working fine, however, if doing major work such as compressor replacement, after which you should flush + replace drier anyway, thats the time to consider converting. I'm not knocking R12, just making things a lot ea$ier from here on. Had the conversion not satisfied me, you can bet I'd be going back with the quickness.
Point blank, the car cools and cools more than adequately. The system was flushed, new drier installed and Castrol synthetic compressor oil with UV dye added. The compressor was used, but a recent remanned which runs very quietly and had clean yellow oil flowing out of it when I opened it. It will last for years.
Remember that I'm driving a 210K car. Do the logic.
You can keep contributing to global warming (
AC-wise) if you want. A cruel twist to all this is that the more you use R12, the more you will need it!
Modified by DrewQ45 at 11:57 AM 3/25/2007
