75amp fuse?
zach-Ka
Car: 1990 240sx (SR)
Any one know why I would pop the 75amp fuse immediately when turning the key? Any help would be appreciated.
dccse3k
well if you are blowing it then for some reason you are getting more than 75 amps. V = I*R so if V is 12v and I is above 75 then i would think your resistance is abnormally low. Maybe a bad alternator? or just a short somewhere
keep-blowing-my-75amp-alternator-fuse-help-t257412.html
that thread may help you
gwar10
Car: 1989 240sx ca18det
had the same problem,when you turn the key and it blows it means your alt shorted out,and needs to be replaced
