4x4 Pathfinder won't shift above neutral position
TheFinder
Car: 1999.5 pathfinder LE
So here is the scoop, my 1999.5 pathfinder wont shift above the neutral position.
I've always driven in neutral with occasional shift into 4lo (because I can't go into 4hi or 2hi). She hasn't ever been off road, I'm the second owner with all the recalls done, and it is at 415,000km.
It physically will not move the stick above neutral and I've tried everything. Any helpful tips, or know why its not letting my shift?
Reason: Revised title
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
Welcome to NICO.
If you were driving it in neutral, I suspect maybe your linkage is thrown off. I don't believe you can drive the car in neutral.
TheFinder
Sorry, the 4x4 shifter in neutral
TheFinder
Wow maybe was stunned this while time. If I can't drive with the 4x4 shifter in neutral... it was in 2 the whole time. Which means, I was in 4hi not 4lo when I switched....
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
Can't drive with the transfer case in neutral. Try depressing the shift knob.
http://www.nissanpathfinders.net/forum/ ... only-down/
