plainzwalker wrote:When the OP said Cobra MAF, is that the Ford Cobra or a brand name? If its the Ford one, how does it benefit? Is it hard to wire up?
Thanks
It's an actual Ford Cobra MAF (p/n: F1SZ-12B579-A). It's been the MAF of choice at Jim Wolf Tech, and is easy to find. Wireing it is extremely easy as well! You do however need the ECU programmed to except the larger (3'') maf however. (FWIW: JWT also offers the 90mm Lightning Truck MAF program as well.
Info on wiring it up: http://www.jimwolftechnology.c...T.PDF
Poor_S13_Driver wrote:Awesome build my friend. I am very curious about swain coating and just went over their website. Sounds awesome. If you dont mind me asking how much was the coating for the exhaust manifold?
I honestly forget. I got in on a group deal, and then also recieved a military discount...I'd like to say in the 100ish range...
Poor_S13_Driver wrote:Another thing I was curious about is your JWT tune. I noticed you dont have a SAFC like I see most other people using to correct the notoriously rich tune associated with his ecus. Yet it seems like your car is running on something very precisely tuned to be making those awesome numbers. Thanks again
SAFC's are simply a 300 dollar way to hack up your harness. For everyone that thinks they need it to correct a 'rich' ecu, there are an double amount of those who have screwed somtehing up by not having them tuned.
Out of the box, JWT (and Enthalpy) rom tunes ARE tuned on the conservative side. Both companies realize that the key to staying in business, is to offer products that DO NOT blow up engines, and because of that tune out ECU's that go in the 11-11.7 range at WOT. Can more power be made at 12-12.3ish - certainly, but a faulty setup on crap parts can be the demise of that fine of a tune (and thus bozo's would blame the ROM tune instead of their thin wallets and cheap part selection)
The advantage of the JWT tune is that it's plug and play, and won't ever blow up your engine. My tune is the first of it's kind for the Mototron 60lb injectors, and it's damn near spot on. I will be datalogging another dyno run in the spring after the installation of cam gears, and sending the log file BACK to JWT for a final 'clean up' sort to speak (if it even needs any), and for the tuning in of a launch control (and for my methonal injection).
Would I need a retune? Certianly not. Car idels at 14.4-14.7, and goes in the 11.4 range at WOT...and is tuned for 91 octane (i'd rather be safe than sorry). I'm hoping that a retune with cam gears will gain me some additonal low end torque (I'd love to have 350 ft lbs), but I'm doing the re tune specifically for the launch control and water injection
