assocpubNSI »
https://forums.nicoclub.com/assocpubnsi-u45931.html
Tue Jun 21, 2011 8:47 pm
Well I'm back from all my travels and ready to get back to working on the 240Z. Sorry to say but the interior is the last thing I will be working on. I've just finished the rear disc brake conversion and I'm happy with the results. Although while doing the conversion I realized that all of the kits out there for sale don't utilize the e-brake bracket from the 240Z. Most use brackets from other cars, ie: Maxima's, 300ZX's, etc. So I decided to take the time and figure out a way to use the existing bracket for my conversion. With a few hours of trial and error I figured out a way to use the bracket from the 240Z that would allow me to use all of the hardware associated with it. In fact, my friend and I are in the process of putting together our own rear disc brake conversion kit. We hope to have the first kits ready for sale by the end of the summer and we think the kits will cost less than $400.00. We think they will be around $350.00. The kit will include everything for installation except for brake pads and fluid.
I've also been busy fabricating other parts for the 240Z. In particular, a choke lever mounting bracket for the series 2 240Z (1972/73) and early 260Z (1974). Never worry again the next time you have to use your choke on any carbureted 240Z and 260Z from early 1972 to early 1974 that use the series 2 console where the choke lever was shifted to the drivers side. This choke lever bracket allows you to bolt the lever to the tunnel instead of the center console (eliminating any chance of cracking the console at one of its weakest points due to a sticky choke cable). With the lever bracket mounted on the tunnel, it also allows for easier console removal as well. No more having to use a screwdriver to disconnect the lever from the console now that it is mounted to the tunnel. The only thing you will need to remove is the choke handle. The kit comes complete with all mounting hardware and instructions needed to install the bracket. Installation is anticipated to be under an hour from start to finish. So if you are looking for a quick fix to an old problem and still want to keep that stock look, then the Choke Cable Lever Mounting Bracket is the easy solution.
Project 240Z is now being prepped for wrapping. I have decided to go with wrap instead of paint mainly because of the price and the fact that I can have a lot of graphics added to the car at no extra cost. I will post pictures when it is done. Should be finished in about a month.
