So I was wrong about the tilting being installed after all, it wasn't installed but rather what you said to do, put the mirror adjustment toggled...GREAT LIFEHACK! How did you know????Rogue One wrote:Just for giggles, you could try this: With the mirror adjustment button toggled to the left side, then the mirrors should tilt downwards when backing up. When the mirror adjustment button is put back in the middle, the mirrors do no adjust.
Again, as far as I know, the reverse tilt-down mirror feature is only available on the Murano, Maxima, Pathfinder, and the Titan. IF this option were to be offered, it would only be on the Platinum and Platinum Reserve editions. There is the off chance that the dealership had it installed on that one vehicle, per customer request, only to have the sale fall through.
Try adjusting your mirror adjustment toggle to either the left or right position (not the center). I bet your mirrors tilt down when in reverse, like mine do!psyman42 wrote:I do have the SL Platinum Reserve Premium car...basically fully loaded with everything and my car doesn't have it. I even checked the website and info on each car and you're right about the Murano and Maxima and other select cars have the feature.
What you said makes sense about the installation being a special order as now I remember reading a small number of second gen Rogues having a remote start installed by the dealer without any problems.
The Rogue would've been greater if it did have those tilt mirrors though....sigh.....
I found this by accident last night on my new 2017 Rogue SL AWD with Premium / Platinum Package. I thought someone was playing with my mirrors after parking in a parking lot. I must have hit the slide button for the mirrors when I got into the vehicle. I couldn't find any information on this in the owners manual so I googled it and it brought me to this forum. After reading the posts here I know how it works now.joanzen wrote:I just today came home with my 2017 Rogue SL with Premium/Platinum/Platinum Reserve Interior pkgs. I also noticed that when I put in reverse, the outside mirrors tilted down. I looked through the entire owner's manual and found no mention of it. However, after playing around in the car a bit, I discovered that if the outside mirror adjustment toggle is in either the left or right position, the mirrors will tilt down when the car is put into reverse, but if the toggle is in the center position, they do not. It's an interesting, hidden feature!
I didn't know you can adjust the mirrors when tilted down. I'm going to have to try that today. Thank you for the extra information.
