http://www.youtube.com/watch?v=SRjeJHtngbg
Here`s the fact.
1) G37 coupe Y-PIPE according to my muffler tech (the actual manager of the shop) is the same as the EX35 Y-PIPE (HR) - Just by looking at it it is the same. He had seen thousands of pipes everyday, which I did not doubt him. I did visually compared the two side by side. Although, we did not measure the hole diameter using a caliper. (Busy shop) Since the old Y-PIPE is rusted out, I decided to install the G37 Y-pipe even if it is the same. The good thing about this shop is , I was free to go inside the bay at will.
2) The G37coupe Midpipe has a much bigger diameter pipe hole than our EX35 and 2 resonators are huge too! The 2 hooks that hold the midpipe to the car`s body (rubber grommet) are not on the right location for G37 coupe midpipe. The tech had to cut those 2 metal pieces and welded it to the midpipe where it will align with the rubber grommet under the EX35 body. Visually at first, the tech aligned the G37 midpipe with the EX35 Mid pipe (still installed) and it looks the same length, but then the G37 coupe midpipe seems to be an inch longer when it was finally fitted in. So, the whole G37 muffler has to push out a bit more to accommodate the extra length. The muffler hooks (3x) are still fastened inside the rubber grommet, but at the maximum position towards the back.
3) The exhaust tips are now sticking out a bit further than when I had the shorter EX35 midpipe. I cannot remember how the stock EX35 muffler sticks out before? All I remember is when I put the G37 muffler on with stock EX35 pipings, the muffler tips went in a bit inside the bumper hole.
What do you guys think? I kinda like the old looks. (G37 muffler only with EX35 stock MIDPIPE) - PARDON the dirty pics....
