Black 2006 G35 Sedan 6MT w/ Aero Package - New Motor and Transmission at 54k miles - JWT Stage 2 Clutch - JWT 13lbs Flywheel - JWT Pop Charger - Z Tube - MD 5/16th Spacer - DC Headers - Resonated Test Pipes w/ CEL Fixes - 350z HR Y Pipe - Coupe Mid Pipe - Custom Generic Muffler - 06 revised 350z suspension - Rolled Rear Fenders - 19 inch Coupe Rims - 245 35 front 255 35 rear General Exclaims - Royal Purple 5w-30 Synthetic - Black Side Markers - Shark Fin - 15% tint all the way around - Polk Audio DB1000 Tweeters - Car Computer w/ 7" Touchscreen - LED Interior, Trunk, Reverse, Plate and Corner Lights - And a 170lb Fat Man!
I use mine every day on my 50 mile commute to work and never had a problemzozoka1212 wrote:Sorry not much help here. I don't know if there are too many G owners using Cruise controll. I know I don't I tried it once to see if it works and that's about it.
Isn't 3-4 mph the exeptable limit?
You can deactivate ICC so that it behaves like conventional cruise control. You have to do this every time you turn on the cruise control. Another way is to tape over the laser.Poyzinous wrote:Read your manual if you have ICC, you can reduce the following distance to make it less sensitive.
But yes, deactivation to standard op cruise control is also an option, I forgot that one...Rangertom wrote:Thanks for you input guys but I have standard cruise control.
Infiniti knows there is a problem but just isn't admitting it. If you work for Nissan, pleade don't waste my time with your BS replies.
Wow somebody is bitter.Rangertom wrote: If you work for Nissan, pleade don't waste my time with your BS replies.
