So you're ECU is tuned for dual intakes but your only running 1 actual intake. The "Dual Intake" doesn't refer to the number of intercoolers, it refers to the number of intakes that you have. When you remove the nose panel the factory airbox lives under there or whatever has replaced it. I'd be willing to bet that you have the factory airbox with a single MAF or a single Popcharger with a single MAF, if your ECU is in-fact tuned for Dual Intakes and you are running a single maf that splits to the two sides then this is your issue. You need to read up on the Dual Intakes setup. Search for Z32 dual intakes or dual pop or dummy MAF.
Your free fish:
https://z32.wikispaces.com/Dual+Intake
If this is the issue, luckily for you all you'll need is a dummy MAF, the elbow kit, and a second Charger/filter. That's assuming that Z1 tuned for that setup, you might want to contact Z1 and find out which map is on your ECU. This would be the "k-factor" thing I mentioned earlier.
