Front-left driveshaft: http://justjap.com/genuine-nissan-drive ... hange.htmlPre-91 Projectors (raised rings around the projector and main beam)
Sidelight : T10/501
Projector : H3c
Highbeam : H3
Haha thanks for the confidence man. I found that same site, but what I cant figure out from it and still don't know is if the bulbs are 35W or 55W on the Skyline. I got they are H3 bulbs, but don't know the correct wattage... anyone have ideas on that?kabob wrote:No offense, guy, but all that was a five minute Google search. Are you sure you can handle GTR ownership?
Thank you for the response. That site for the driveshaft was exactly what I was looking for and struggling to find.kabob wrote:http://www.gtr.co.uk/forum/154852-r32-g ... guide.html
Sidelight : T10/501
Projector : H3c
Highbeam : H3
Adjustable front upper camber arms are all over eBay; just do a search. Or you can buy them off of members on GTRCanada, Skylineowners.com, gtr.co.uk
I'm assuming you mean the lower control arm when you say "lower trailing arm thingy": http://www.ebay.com.au/itm/Nissan-Skyli ... 0731266083
HKS filter: http://thmotorsports.com/i-238436.aspx? ... oCwCbw_wcB
From what I've been able to dig up, they're H3C 55w bulbs (not H3).crainbow wrote:Haha thanks for the confidence man. I found that same site, but what I cant figure out from it and still don't know is if the bulbs are 35W or 55W on the Skyline. I got they are H3 bulbs, but don't know the correct wattage... anyone have ideas on that?kabob wrote:No offense, guy, but all that was a five minute Google search. Are you sure you can handle GTR ownership?
I havent been able to find anything that would bolt onto MAF. Wish it was just a tube hose clamp fitting on it.AZhitman wrote:I'd throw a cheap ebay foam filter on the end of the MAF and call it good.
Road Safe? In terms of the damage, yeah I am definitely going to fix everything before its driven. Is there something else you are getting at by road-safe though?kabob wrote:Careful, OP. I just now looked through your pics and there's no way that car is road-safe. You don't already have it in your possession and registered yet, do you? It's not 2015 yet.
Thanks, I am still debating it. Might just get it to a safe point to drive... might try and tackle body work myself... not sure yet. I know its probably not worth it to pay a shop.themadscientist wrote:If it doesn't have a bond release, whatever you were told, it's not right. Everybody thinks they have the trick figured out, but it's always themselves they tricked. Good luck at any rate. Even if it was fully legal the amount of corrosion you have there is past the point of saving.
Also JustJap.com will not ship outside of Australia... So that's out. On the hunt for a CV Axle again...kabob wrote:http://www.gtr.co.uk/forum/154852-r32-g ... guide.html
Sidelight : T10/501
Projector : H3c
Highbeam : H3
I believe you misread the chassis plate. According to epc-data.com, his car is a Dec 1989 car (not 1990) in Diamond Black Pearl Metallic so that's the original color and with that much paint corrosion, I'd say that it's the original paint. V-Spec R32s didn't come about until 1993 and I only remember R34s coming in Lightning Yellow.AZhitman wrote:First glance (mostly 'obvious' stuff):
According to the serial #, that car was originally a Lightning Yellow GT-R V-spec. I don't see any evidence of yellow paint under the black, so I'd be looking REAL close for some welding evidence.
Thiskabob wrote:I believe you misread the chassis plate. According to epc-data.com, his car is a Dec 1989 car (not 1990) in Diamond Black Pearl Metallic so that's the original color and with that much paint corrosion, I'd say that it's the original paint. V-Spec R32s didn't come about until 1993 and I only remember R34s coming in Lightning Yellow.AZhitman wrote: According to the serial #, that car was originally a Lightning Yellow GT-R V-spec. I don't see any evidence of yellow paint under the black, so I'd be looking REAL close for some welding evidence.
http://nissan.epc-data.com/skyline/bnr3 ... R32-004320
This car is 50% S13, 40% Z32, and 10% R32. it shares a lot of its suspension with the S13. The front struts and upper control arms are different. the Front Upper control arms are the same as the Z32, the entire rear suspension is identical to the S13.crainbow wrote:Does anyone know if this car shares suspension with any US sold cars?
kabob wrote:Just get someone's used Skyline coilovers unless you want to put it together front and back separately. As for the CV joint, the only possible part compatibility is the G35x or M35x as nothing else in the Nissan/Infiniti lineup used the ATTESA all-wheel drive system.
I still can't believe you're trying to get that illegal rolling junk/rust heap road-worthy.
The fronts are different than most anything we have state side. I ordered my greddy coils from GTRgarage. Sold the coils that came with the car on Skylineownersusa which I believe someone had a used set of cusco or tein's on there.crainbow wrote:Thanks for the info on those dealers. Shot them an e-mail and Ill see if they can get the axle. I guess when I stated suspension parts, I meant the coilovers themselves. Are those shared with any US car?
Does any US made car share the front left CV Axle? Cause that would be awesome.
really depends on what "road worthy" means to you... I agree, but maybe he really did pay like 12 dollars for this car and it makes sense to....kabob wrote: I still can't believe you're trying to get that illegal rolling junk/rust heap road-worthy.
