Listed Below are some of our projects from 2007 on into 2008 ! ===============================================
Recently we finished a:1995 Nissan S14 Zenki build:Bored & Built SR20det, Je Pistons, Manley Rods, ACL coated Race Bearings, New OEM Water PumpNew OEM Oil PumpHKS Cams/Gears, Crower Valvetrain, Peak Boost Turbo Manifold, GT3071R Turbo, Tial 44mm Wastegate HKS Racing BOV Greddy Replica Intake Manifold, HKS Fuel Rail, SX Fuel Pressure RegulatorAeromotive Fuel Filter Siemens Fuel Injectors, Kaaz Limited Slip DifferentialGreddy power pulley set, Custom Catch can setup, custom air intake setup, LOTS of AN Fittings and SS Braided Hose Koyo Radiator Dual Spal Puller Fans Apex'i GT Spec Exhaust, In house fabricated down pipe, In house fabricated test pipe, Bar & Plate FMIC, In House fabricated piping, Exedy Hyper Single clutch, 1 piece aluminum driveshaft, Apex'i EXV Coilivers, Wilwood Brakes, C-West Body Kit, Chargespeed Wide Fenders & Quarters, Seibon CF Vented Hood & Seibon CF Trunk Lid, Zenki German Headlights, AEM Engine Management SystemDefi Gauges & Controller, Greddy Profec B Boost Controller, HKS Turbo Timer, CF Door Panels, Autopower Roll Bar, ATL Racing Fuel Cell with In Tank 100psi Pump & Surge Tank, Remote battery relocation. Corbeau Seats & Corbeau 5 Pt. Harnesses5Zigen FNO1's & Cooper 2XS Rubber And i am sure some things i did not list !!!!!
Rest of Pics >
http://s251.photobucket.com/al...%20Up/ ... ======1998 Mitsubishi Eclipse GST 1. 4G63T - 6 Bolt Block Bored, Honed, & Hot Tank Cleaned 2. 3Axis Angle Valve Job on Cylinder Head, cut for Oversize Valves3. Main & Rod Bearings with Race Bearings 4. Ferrea Valves, SuperTech Valve Springs & Titanium Retainers, new Valve Seals5. CP Pistons 85.5mm and Peak Performance H-Beam Connecting Rods 6. New Mitsubishi OEM Oil Pump & gears, Water Pump, 7. Custom Cometic Headgasket 86mm Bore .054 thicker than stock. 8. ARP Head Gasket Studs 2.09. Moroso Oil Pan w/ Wet Sump 10. Prothane Engine Mount Kit 11. Quaife Limited Slip Differential 12. Driveshaft Shop Stage#7 Axles 13. ACT XTR6 6 Puck Clutch / Extreme Pressure Plate14. ACT Lightweight Flywheel 15. Peak Boost Equal Length Turbo Manifold for 44mm Wastegate16. Garrett GT35R Ball Bearing Turbocharger, Custom Trim & Custom A/R17. TIAL 44mm External Wastegate .50Bar Spring Installed18. Zerolift Race Bar & Plate Front Intercooler19. HKS SSBOV V2 w/ 65mm Flange20. Zerolift Custom Polished Intercooler Piping w/ Silicon Couplers & 3" Clamps21. HKS 4G63 Kevlar Timing Belt & Tensioner Kit 22. HKS Camshafts & HKS Cam Gears 23. Magnus Intake Manifold for 1st Gen. & 75mm Throttle Body24. JG Edelbroek 75mm Throttle Body Assembly25. Custom Fuel Sumped Fuel Tank26. SX In Line Fuel Pump & SX Filter 27. SX Fuel Pressure Regulator (-10)28. Many Feet of Stainless Braided Line and ALOT of AN Fittings 29. Autronic CDI Ignition Box 30. Zerolift Custom Coil On Plug Ignition Coils & Cover Plate31. NGK Wideband & O2 Sensor32. AEM Fuel Rail & 1000cc Injectors 33. AEM EMS Stand Alone Management System 34. Greddy Oil Cooler and SS hoses35. Fluidyne Aluminum Radiator, Custom Radiator Hoses, Custom Overflow Tank & hose36. Zerolift 3" Custom Made Downpipe and 4" Exhaust, Custom Made Dump Pipe37. TEIN Flex Coilovers with EDFC 38. Stoptech Big Brake Kit 39. Full Stainless Brake Hoses 40. Custom Air Filter Intake Kit 41. Custom Mount Oil Catch Can and SS Hose42. Defi - V2 Control Unit43. Defi - BF Boost Gauge44. Defi - BF EGT Gauge45. Defi - BF Fuel Pressure Gauge46. Defi - BF Oil Pressure Gauge 47. Defi - BF Oil Temperature Gauge48. Apex'i AVC-R Boost Controller 49. HKS Gen. 2 Turbo Timer 50. Autopower Roll Cage, Bolt In & Weld In51. Bride Brix Reclining Seats - Black/Gradiation 52. Bride Floor Brackets & Sliders 53. Seibon OEM Carbon Fiber Hood 54. HID Headlight KIt 55. Sparco Steering Wheel & Hub56. Takata Racing Harnesses57. Battery Relocation Kit 58. Enkei G-Spec 18" Wheels * Sumitomo Tires 59. Carbon InLay Dash Trim
The Rest of the Pictures can be found at :
http://s251.photobucket.com/al...lipse/
=================================================Previous Project- S14.5 Build Up
Rest of Pictures >
Couple of Key items. SR20detGT2871RHKS SS BOVKoyo RadiatorZ32 BrakesKei Office Coilover Suspension Suspension Link Arms Kaaz 2 way Autopower Roll Cage Recaro Seats Takata HarnessesAlot more.............................
=================================================2006 Season Race Car - S13 Coupe
http://s251.photobucket.com/al...20Car/
=================================================Currently In Progress we have :
S13 Convertible - Upcoming Race Car
Custom Roll Cage IKEYA Suspension Linkage Function & Form Remote Reservoir Coilovers Alloy Subframe BushingsSuspenson Techniques Sway BarsWilwood Brakes Kaaz Differential Differential Ring Gear ATL Fuel SystemCustom Built into floor box for fuel cell Completely stitch welded chasis and tubbed front wheel arches. Custom C&R Radiator & V-Mount IntercoolerSeibon Carbon kevlar Seats Seibon Composite Doors Origin Lab Aggressive Body Kit Origin Lab Wide Fenders & Quarters Enkei RPF1's
MUCH MORE TO COME > More pics at :
http://s251.photobucket.com/al...t=all
===============================================Civic Drag Car Build :Built, Bored & Sleeved B18 TO4z Turbo Full Race Turbo Mani Way Too Many parts to List : Check out the Pictures >
More Pics at :
http://s251.photobucket.com/al...%20Up/ ... ========We Currently also have 3 RB25 Swaps In Progress 2 SR20 Jobs - 1 with Build Motor & GT3076RIntegra GSR Turbo Eclipse GSX Turbo Build ===============================================Lastly Feel Free to Contact us with any questions, if we can be of service in providing you with Parts/Engines/Service.Thanks. Zerolift Staff
Modified by ZL-Auto at 10:06 AM 1/7/2008
