rendog831 »
https://forums.nicoclub.com/rendog831-u269894.html
Sat Apr 15, 2017 5:54 pm
Hi everyone, I need help with my gauge cluster. I have a 1990 TT. Recently I did a LED conversion on my cluster. I also swapped out the black OEM gauge faces with the NR white gauges. After installing, I wasn't happy with all the hot spots so I Put the black faces back on only leaving the boost and oil pressure gauges white(looks amazing). I also deleted the fog lights and switched them with LED fog lights. At first everything worked good for about 2 days. Now, none of the illuminating LED's in the cluster go on and neither do the fog lights. All the warning led's work well. Also when I turn on the headlights(low beam), only the high beams turn on.The low beams just don't turn on. When I pull the turn signal stalk, the high beam indicator does not turn on in the cluster either. I have a second cluster which I tried to switch over all the parts but ended up with the same thing. Is there a fuse or something that I might have blown. I'm stuck and I don't really want to buy a third cluster. Any help would be much appreciated. Thank you.
Rogue One on Sat Apr 15, 2017 6:27 pm, edited 1 time in total.
Reason: Moved to correct forum
