Z32 tt idle problem
Markdailymd
Car: 1993 300zx tt
I just bought a 1993 300zx tt, and it was having trouble holding idle when I bought it. I was told the injectors needed replacing. I did so, Lang with the spark plugs, fuel filter, oil, and the fuel in the tank. I just got it all put back together and it's idling high, around 2000 rpms. It's also fluctuating up to 2500 rpms, like clockwork. It also redlines at 4500 rpms, which is far too low. I suspect a vacuum issue, but not sure where it's coming from. Any one have a clue as to what I may need to do? Tia
nissanfreak12
Car: 92 300zx 2+2 TT
I would suspect a boost leak as well. This is a must have tool for a TT;
https://www.z1motorsports.com/z1-produc ... -1867.html
You can make one yourself, find them cheap, or even use a smoke machine.
