evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Jan 27, 2010 6:44 pm
you shouldn't have to change the slave, if you have a high pressure plate you have increased pedal effort, thats the trade off, I have the southbend clutches stage 4 and it has noticibley more effort but very tollerable, if you don't like a stiff pedal stick to a stage 3 or lower
if it feels spongy then you have a problem, I once got a bad pp form competition clutches that the stock pedal just could not fully disengage it took soo much pressure, sometimes a bad product gets to the consumer, they got me the correct pp after I figured otu what was going on, also if there si any air in the system or the pedal isn't adjusted propery you can encounter issues
are you sure it's a tripple plate clutch? or is it maybe a three puck (very different animals)
