Both the transmission and the blocks dowel pins are used to locate and hold the tolerance. I wanted to get everyone’s thoughts on this plate, and currently I’m working on making one that is using either 1/2" alum or 12mm thick cast alum plate with CB's to use the factory (m14-1.5mm fine thread bolt style) and machine the bell housing. And if any one is in question of the specs, I can tell you that I have been a mechanical engineer for 8 years now and I have ran all the stress tests I can run on the plate and the bolts and can not find a single issue where it could fail and will post the results and the math for anyone to check. Now for some pics.
