Z32 Suspension
ghost4g63
Car: Z32 TT
I was just wondering if the struts and springs were interchangeable with the TT and NA? Gotta do suspension on my brother's Z32 NA with TT swap, and just want to make sur ei don't order something i can't use. Thank you.
NolimitZ32
AFAIR yes. What are you planning on putting on there?
ghost4g63
Car: Z32 TT
probably going to go with the DNA coilover kit from ConceptZ
DCaff300ZX
Car: .
1993 CRP TT- Modified
The suspensions are interchangeable for the most part, except the rear subframe and using the sway bars from one to the other due to size.
The TT has HICAS and slightly different subframe sizing IIRC making a swap for a NA AT sub not really possible without mods I've been told (wanted to do this) and the sway bars for the TT especially in the rear are beefier, which may make cross application hard or force you to swap connectors as well.
