DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sun Jun 28, 2015 5:52 pm
Welcome to Nico!
Given your preference for a stock setup, the KYB GR2 shock is a popular choice for cost and performance, very close to stock. If you check spme of our better vendors such as ConceptZ performance and Z-1 Motorsports you can also assess other brands and configurations for your Z, and get the best costs and availability.
You should be aware that your Z most likely will need new springs as well which causes a camber issue and worn tires, service time usually at the same interval as your shocks. Should you decide to go to coilovers as a one-stop solution to needing both items, more parts must be replaced although they may need replacing (front and rear upper control arms and front tension rods), and our vendor Powertrix offers a top of the line choice for that solution and the best costs and service possible.
My advise would be to have your entire suspension checked due to being a true multi-link suspension, where all parts need to be in spec for correct operation, and go about your parts search from there knowing exactly what you need. There may be some brake, ps rack leakage, and tie rod issues in your 24 year old car to consider as well...good luck!
