Z32 Passenger Window Won't work
Clark45
Car: 1993 Nissan 300zx 2+2 NA
I have a 1993 300zx. I put it in the garage over the winter to some work on it. A few weeks ago I realized the passenger window stopped working. Bought a new motor and new window switches and still nothing. Any help with my problem is apreciated.
rgregoryb
Car: 1992 300ZX 2+2 NA
Mine was a bad ground wire, which I found after buying the switch. Does it not go up or down?
rgregoryb
Will it work from drivers side?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Did you double check the "safety lock" button on the driver side is not activated?
Or you may have a window amplifier problem. Check if there is power to the motor, if not look at this link:
http://www.twinturbo.net/net/viewmsg.as ... id=1126623
Clark45
I got it too move when I bypassed the passenger side switch. I made sure it wasn't the child locks a thousand times. I bought a new passenger side switch and that did not do anything. It works from neither side.
rgregoryb
Check the ground wires at the switch plug in. There are actually 3 grounds, use an ohm meter to see if they are actually grounded
Clark45
I pulled out the driver side switch and took the child lock button out and there was a spring that wasnt on anything. Think that it may be the problem.
