If you say you've done all the wiring correctly, then start looking at the the computer/tune.greensx wrote:Bump any other ideas from anyone?
Ya, post a vid if you can. Only reason I said that was because I had the same issue when I was running a KA-E MAF on my CA. It worked fine but when I had it unplugged while running and plugged it in it would spudder and die. Only other thing I can think of would be to make sure its wired up correctly.greensx wrote:No man i've tried both the maf plugged in and not plugged. I've sprayed maf cleaner on both mafs so it's not that. I could post a video on whats happening if it would help
