MasterOSkillio »
https://forums.nicoclub.com/masteroskillio-u140085.html
Tue Sep 18, 2012 9:58 am
ok, so I think I was able to partly answer my own question. It appears the Nissan Pathfinder or d21 pickup from 1994 came with a BMC that was 1" like the S15 that had a Split point of kPa (kg/cm2, psi) 2,942 (30, 427) and a reducing ratio ´ 0.2. Exactly the same as the S15 as well. There are 4 bmc options for this suv/pickup, the one you want is the bmc used with the rear abs drum brakes.
On the down side the ports on the bmc are on the wrong side for the brake lines to hook up, so I would have to come up with some custom piping. For those of you with no ABS it appears this system has three holes for brake lines instead of just two.
I am going to see if I can find look through some more fsm and find a bmc that has the same split point and reducing ratio, that will bold right on.
EDIT:
After Further research I found the 98 Frontier 4wd and the 2000 Xterra both have the same 1"bmc, split point and reducing ratio. Both options have 2 holes for brake lines (better for people with ABS) the holes are mounted on the wrong side, of the bmc, so redoing some of the brake lines would be necessary.
If anyone knows of a BMC that has the same specs as the one from the S15, and has all the holes for the brake lines to fit without modification, please let me know.
