evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Jan 20, 2009 5:21 pm
FICV = fast idle control valve (generic name for idle up circuit such as your ficd)IACV = Idle air control valve
the ficv is supposed to open up when the engine is cold (unless the car also had a cold start valve) or when the a/c is on to compensate for the extra load
the iacv is to regulate airflow at idle speeds, it's asjustable, too much air and the idle goes up, too lottle and the car chokes out
ignition timing and afm can also effect idle speed
