MoldyOldy240 »
https://forums.nicoclub.com/moldyoldy240-u41784.html
Fri Dec 21, 2007 12:42 pm
hmmm... this is like, the third or fourth one here in the past week, but all have different conclusions. Lets see here
This happens sparatically ; just started today:
Car: 1991 Nissan 240sx Hatch Back 5 spdPerformance parts: No known after market, only serviced by NissanRecently replaced parts: Previous owners son put a used O2 sensor in 1 month ago (cheap jerk spent 15 bucks to save 25)Engine Codes: 45 (Injection Leak)Symptoms:
Sparactically occurring; when car is in neutral, or when clutch is pressed, the idle will drop from 800 to about 300 and start to choke out. It goes back up with no interference from driver to about 1100-1300 and then will dip back down to 300 a few times. A couple times it has caused the car to die.
This happened while the engine was warmed up.
When it dips there is a heavy rich smell, leaving me to beleive there is no problem with the fuel or spark.
Checked wires, wiggled injectors vigorously to see if maybe it was a loose wire; no change in engine performance. All hoses are recently new (performed by Nissan by previous owner).
Theory:
Since the O2 sensor was used, I went ahead and purchased a new Bosch O.E. O2 sensor to see if this will fix the problem, and am right now waiting for the engine to cool down.
Any suggestions gang if its not the O2 sensor?
I hope the format I am using helps you all understand where I am coming from
