Hmmm i dont have my knock sensor hooked up either and it runs sluggish until i hit 3k + rpms. Maybe this would be my problem as well. Also, when i give my car gas when i first start the car it almost dies until it warms up, then it runs good.
I just recently did my swap as well, and my idle was great (when there is a vacuum LOL) then i plugged the vacuum line and it idles very rough! It turned out to be my coil pack, that was bad (i though i was an injector, good thing it wasnt). There is also a idle control screw on the intake manifold, maybe you can mess with that, i also heard there is an idle control screw on the ecu itself.
nnkfws333 wrote:We replaced the timing belt sdtouge but the car ran fine just had an idle problem and then a knock sensor problem. When I drove with the knock sensor off, it would run crappy till 3k and drive fine...so Im not sure if this would be a problem.
