Probably not without doing some type of compact HID retrofit which is becoming harder to find. Lamin-x is a viable solution
http://www.lamin-x.com/. If you decide you no longer like yellow fogs simply remove the film and you are back to clear lenses. Or you could always use a glass stain made by Krylon. Obviously more permanent but looks good (Have seen in person). I've always had better results with a colored lens illuminated by a high quality pure white bulb (Sylvania Silverstars, GE Nightbreakers, PIAA, HELLA, etc)
