Y33 ATF Cooler - Another mounting location?
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
Right so keeping the stock system in place will allow faster warmup to achieve lockup. When it hits 180* the cooler valve opens and keeps it cool.
This is assuming the cooling system is good condition. Draining and refilling radiator is part of the install. probably a flush as well.
LongBeachQ45
Car: 1997 Q45/Cima Hybrid
just so I dont feel like a complete tard, the setup with the least amount of backpressure is original cooler, aftermarket cooler, then filter? Any new words on the 90 degree elbow debate?
Skibane
Car: 2000 Q45 AE 110K
Plumbing the original, in-tank cooler in parallel with the Flex-a-lite aftermarket cooler (with the output of both coolers combined before passing through the spin-on filter) resulted in less backpressure than using either the original in-tank cooler (with no spin-on filter) or the Flex-a-lite cooler by themselves.
The presence of five 90 degree elbows in this parallel hook-up didn't seem to affect the backpressure - it was still considerably lower WITH the elbows (and spin-on filter) than the stock cooler (and no spin-on filter) was WITHOUT them.
Modified by Skibane at 2:34 AM 8/19/2007
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
So I missed this.
I thought Skibane eliminated the coke can in the lower radiator tank due to back pressure? But now I see that it is in parallel.
No external ATF filter on the FGY33 like the G50 either. Think I will be in SA in October.
