pnanda16 wrote:1. engine is off
Although the battery voltage will be higher immediately after you shut the engine off, it shouldn't eventually settle to any thing less than 12.6 volts (edited for brain fart!).
Quote »2. idle[/quote]The voltage will be between 14.1 and 14.7 volts, depending on ambient temperature, battery state of charge, etc. In cold temperatures, the voltage is highest, and drops as the temperature increases.
Quote »3. under full load (AC, Lights, Audio @ high volume, rear defroster...)[/quote]This voltage depends on how many loads you have connected - pretty hard to put an actual number on it.
Rather than guessing about your battery's condition, you might consider having it load-tested. Auto Zone (and other places that sell batteries) will usually do it for free. Essentially, this involves placing an exact, heavy load on the battery while checking to see how well the battery voltage holds up. If the battery passes this test by a comfortable margin, it's probably still got some life left in it.
