conquestkid »
https://forums.nicoclub.com/conquestkid-u122768.html
Sun Dec 21, 2008 5:27 pm
My 2000 Xterra 3.3 was running great, then sitting a stop light tonight it kinda stumbles a little then dies. It started back up and I was able to make it home but it wanted to cut out some a I drove home. As long as it wasn't under a real load it seem to run pretty good. I got home let it sit for a bit then went back out to check on it, it will start fine and idled good except at one point it wanted to stumble and act up briefly then returned to a good idle. If I put it in gear and hold the brake while giving it some throttle it will idle up a bit then start to break down or stumble, kinda like what a plug wire would do. I'm not getting an engine light, so any quess as to where I should start first. It has 104k on it and I bought it used so I don't know any history on it. Just wondering if the fuel pump could be acting up or could it be a clogged filter. Any suggestions would be greatly appreciated. Thanks in advanced!!!
