WTB: Stock intake pipe (turbo to MAFS/Filter)
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
Does anyone have a stock intake pipe, from the turbo to the MAFS/Filter???I know I should of posted this in the Sales portion of the forum but I thought this might help me a lot better.Thanks!
Email me at [email protected] me at nnkfws333
NeedCAforS13
Car: CA swapped S13 coupe
we need a stock intake pipe peoples! might just try making a copy of mine I suppose...
Sean
sdtouge
Car: 1990 240sx coupe
lol you should.
just whatever you do, if you cant get the stock box to work with it dont decide that it would be smart to remove the coil inside of it lol, now my whole system is all ziptied to itself and **** lol. its still kinda kinked
fanta
sdtouge wrote:lol you should.
NeedCAforS13
sdtouge wrote:remove the coil inside of it
becareful with that... one of my friends with a CA here in town removed his coil and his intake pipe was collapsing under the vaccum caused by the turbo sucking in air we couldn't figure out what it was for the longest time! haha
but neither of us are using the stock airbox... I have a stock rubber elbow attached to a cone filter, and he'll be using the same thing
Sean
biosehnsucht
Ditto, thats how mine's hooked up.
I need to get a custome one made tho, so I can hook up my sheepdog BOV to recirc.. just need to get one made such that I can have a short little pipe connect the BOV to the intake pipe, the way its mounted up (if I installed it, it isn't on right now as I don't want to have open BOV rich problems) thats how it would work..
cadet
Car: 89 s13 coupe
I run open bov (hks) and don't have bov rich problems...
float_6969
I'm working on something as we speak, but I don't know if I can get the cost down to a reasonable price. What would you guys be willing to pay for something like that? It would be metal instead of rubber.
biosehnsucht
if I had the moeny to spend, alot.
right now things are always tight
nnkfws333
biosehnsucht wrote:if I had the moeny to spend, alot.
TRUE THAT!!! I dont know about a lot
float_6969
Well it cost me $45 for just the flange to attach to the turbo, but they had to CNC the flange from sheet steel. I'm sure they could do it for less if I was buying a bunch instead of one. when I get it on the car and make sure it works, I'm going to take the car down and have them fab up a pipe and see what they want for a run of them. I'll keep you guys updated as I find out more...
biosehnsucht
Would the pipe you're having fabbed up have a place to plumb in the BOV to recirc? the way the hotpipe I have w/ sheepdog BOV on it mounts the BOV faces towards the inlet pipe so I would just need a properly sized fitting coming off of the pipe, and a small peice of properly sized hose (probably harder to find that, its not a normal size) to join the two..
sdtouge
ya if you could get a spot for the reecuircualting bov bung that would be aewsome....
