WTB::::: injector dropping resistor
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
I need a injector dropping resistor ASAP i have paypal and can send money now. Will i damage the ECU or anything running my car without one?(to test start/run)im a idiot and didnt buy Dee's quick enough
Akihisa
Car: 300zx, Italjet Formula 50Lc, Italjet Dragster 180
I have a new one but I cut the connector off it. Let me know if you could use it.
yourmomsrps13
no problem i cut, solder and heat shrink all day at work its for a CA though so i just have to match the wire colors?
thanks
zero_gripS13
Car: soon to be 95 s14 hopefully
whats the dropng resister do?
em55ery
Car: 91 nissan 240sx
i have one right here. let me know if u want it
yourmomsrps13
i want it (thats what the post is for)lolneed one ASAP so whoever gets me one first
Akihisa
I just sent you an email. $35.00 shipped sounds about right. I forget what I payed for it. Let me know.
biosehnsucht
you can easily damage the ECU by hotwiring the harness to bypass the dropping resistor, unless you switched to high impedence resistors and retuned the ECU..
yourmomsrps13
biosehnsucht wrote:you can easily damage the ECU by hotwiring the harness to bypass the dropping resistor, unless you switched to high impedence resistors and retuned the ECU..
what if i dont plug in a dropping resistor at all and start it will that damage the ecu?
biosehnsucht
you cannot run without a dropping resistor on an unmodified harness. the injectors will NOT open, as there is no power reaching them (or they can't reach ground, so no power flows through them.. forget which side the resistors are on)
if someone screws up the harness and bypasses the resistor, then you can have problems.
yourmomsrps13
ooooh ok GREAT then thats why my car will not start and i havent done any damage woohoooo, doh! now i just need that dropping resistor
ca18detdrift
Car: 89 240sx
if you really want to buy one i have an actual ca18det one with the plugs and everything. I bought it on here about a month back but it turns out i already had on in my harness lol.
[email protected]
$15 + shipping =)
yourmomsrps13
email sent
