a lot of people? since when?Shady195 wrote:3. VG30DETT's use two(2) garette T25's ( a lot of people scrap the TT setup for a single bigger turbo)
Weber3211 wrote:a lot of people? since when?
for the longest i have been wanting to turbo my J30 which shares the same motor as the 90-96 300zx NA...in order to TT that particular motor there would be a lot involved...its not impossible its just that its reliablity would be very questionable once it was done...thats why people just swap the TT motor in...there are enough differences as subtle as they may be that would make it more time consuming as opposed to just swapping in a TT...if you cannot afford that theres always the other route which more and more people are getting interested in here lately and what i have decided to do with my J30...swap a vh45...stock it puts out almost 100more hp and lbs/ft torque than a stock TT...check the VH forum here and you will see at least 3 people who are either done or almost completely done with the swap...out of those 3 2 of them are twin turboing the car....sorry for rambling but in the end it all comes down to what youre willing to put up with ie how long your willing have the car down for as well as how much money you have to play with and finally the end result....either way i wish you the best of lucknissian240 wrote:Have many people gone this route?I'm well aware of detenation that could occur do to pre-ignition in the combustion chamber but there are ways to get around that.How bad could it be? Besides detenation is the motor pretty stout?
you have some wrong info not sure of the torque exactly but the stock VH45 puts out 278HP<TT 300HP.kbflip02 wrote:swap a vh45...stock it puts out almost 100more hp and lbs/ft torque than a stock TT...
