Check to ensure that you have the correct piece and that it fits.
Step 2:
Warm up each piece. You can either put them on your vents with the heat on high (warm) or use a hair dryer.
Step 3:
Use alcohol pad to clean the area.
Step 4:
Use the 3M adhesion that they provide you. Use on the corners. Do not apply to actual product.
Step 5:
Peel a portion of the tape back.
Step 6:
Place it on and slowly peel back the tape as you align it.
Step 7:
Using a cloth, push down on the piece you have just installed. This will ensure that it bonds properly to the dash.
Finished product:
