I'm still confused, are you saying that that transmission ecu doesn't hook up, or just the ECU? Let me give you a hint, There is only one ECU....Ghost_silvia wrote:Mt computer(ecu) does not hookup to the wiring harness.
It's easier to install the motor/transmission together. And no, there is no seperate computer for the transmission.Ghost_silvia wrote:So the comp under the armrest is for the power windows? Also for your swaps all you did is connect the transmission from under the car? No special comp for it?
