biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Fri Oct 14, 2005 8:29 pm
OK yeah the 4 important wires that I took note of are the same between the two, or should be:
Yellow w/ Green stripe: SpeedoYellow w/ Red stripe: TachBlue w/ Green stripe: Thermo Control Amp (part of the AC system, teh ECU cuts this to kill the AC when you go WOT for more powerOrange: 12V / 10A fused Ignition Start signal
the car will run without all except the Orange wire, but you want them all hooked up.
Not sure what else goes through off hand but if you connected same colors you should be fine.
