Wiring help!!
JC87HB
Car: 1987 Nissan D21 HB
ok so i installed my aftermarket Tach from Sunpro.. i got everything wired except the internal illumination. I have the tachs power running to the ignition switch and grounded to a well...a ground.. and my tach readings wired to the wire off the ecu in Position 3. Any who i was wondering how i could get the light wired to the trucks light switch. Anyone have a clue?
mrecoolgar
Car: 1990 Hardbody Reg Cab 2WD 2.4 5SP
Simply tap into an existing hot wire and a ground.If you have a glovebox lamp, an ashtray lamp or even the climate controls.That circuit comes alive when your parking / headlamps are on.That circuit carries a pink-blue stripe wire in my 90.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Use a fuse tap to give you a power source for lighting. Just make sure the source you use switches off when the truck is off.
JC87HB
Thanks ALot guys!!!! much appreciated!
RT
Car: 1991 nissan king cab pick up
Radio hot wire is easy to get to and will have enough power to light it when switch is on.
RT
even easier is the lighter, that is where I tapped for my aftermarket volt meter
