wiring help needed!!
kylekinnamon1989
Car: 90' Nissan 240sx SE/ SR20DET
ok so, ima cut it short.. out of know where, all my vacuum lines and wiring harness got wrapped around my fan!!! there is a black/ gray stripe and brown/ gray stripe wires that go into a little clip, its comes from the same wiring harness that the maf sensor wires come from.. what does that connect to??? i cannot find it anywere. also, there are three vacuum lines that come from under the intake manifold that connect to the other side, i found 2 of the homes for them but cannot find the 3rd, also, i dont even know which ones connect to which.. please help
