Wipers won't work with brights on!!!
ShadyTreeMech44
Car: 2013 Nissan Rogue SL
I'm new to the forum and hope someone can help me. I have a 2013 Rogue SL. The wipers work fine with the low beams on but as soon as you put the high beams on they stop completely. If you switch back to low beams the start workings again. Also if you have the high beams on for a little bit the low tire pressure light will start flashing. It will stop flashing when you switch back to low beams. I also noticed when I had the hood up with the high beams on, there's almost like a buzzing sound coming from the fuse relay controller (fuse box) under the hood. Again it only does it with the brights on. The car was involved in an accident which leads me to think that maybe one of the circuit boards in the controller may have been damaged. It's an awfully expensive part to just to buy on a hunch. It runs a little over $300. Any help would be greatly appreciated. Thanks.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
What does your mechanic say about the issue?
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
ShadyTreeMech44 wrote:I'm new to the forum and hope someone can help me. I have a 2013 Rogue SL. The wipers work fine with the low beams on but as soon as you put the high beams on they stop completely. If you switch back to low beams the start workings again. Also if you have the high beams on for a little bit the low tire pressure light will start flashing. It will stop flashing when you switch back to low beams. I also noticed when I had the hood up with the high beams on, there's almost like a buzzing sound coming from the fuse relay controller (fuse box) under the hood. Again it only does it with the brights on. The car was involved in an accident which leads me to think that maybe one of the circuit boards in the controller may have been damaged. It's an awfully expensive part to just to buy on a hunch. It runs a little over $300. Any help would be greatly appreciated. Thanks.
Are you still under warranty?
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
it could be the combination switch. have it replaced.
it could be the relay fuse for the high-beam. have it replaced
it could be the fuse box. have it replaced
ShadyTreeMech44
No it's not still under warranty. I replaced the relay and it still does the same thing. I'm afraid I might have to bite the bullet and replace the the whole controller :facepalm:
Return to “Rogue Forum”
