I just found a crack at the bottom of the reservoir. Any suggestions for replacing the tank? Also I found a tank kit on a website for $112 including pump,packing and sensor. Is this reasonable?
Postby
370Z/28 »
https://forums.nicoclub.com/370z-28-u126175.htmlMon Jul 23, 2012 5:54 am
All you need in your toolbox is duct tape and WD-40. If it moves and it isn't supposed to, you use the duct tape. If it doesn't move and it is supposed to, you use the WD-40.
