I recently had this same issue after installing some other parts. It turned out that the pump would spray with my hood up, but not down.ocho wrote:Hi every one! My washer is not washing. I've checked for a burnt fuse but found none, visual inspection shows the reservoir is full all the lines are ok but i can't find the pump's location. Can someone indicate where it is located, I dont want to dissassemble the whole front just to find it is not where I thought it might be.Please come to my rescue so I can check it and /or replace it.
OCHO
