Will this work?
groundhogday1976
Car: 2015 Altima 2.5 S
I know the answer to this is probably no, but will a '89-'91 5-speed from a single cam KA car fit my '93 twin cam without modification? I just found out my warranty doesn't cover teardown and diagnostic, so I'm gonna try to get a used 5-speed and put it in myself.
lessthanjakejohn
yes
groundhogday1976
Really?!!! Kick ***! BTW, what would it weigh (so I can find out shipping costs)?
lessthanjakejohn
you mean a transmission right?
groundhogday1976
lessthanjakejohn wrote:you mean a transmission right?
Yes. Also I need to know the dimensions (length, width, height).
wiwalsh
Car: school, and my 240!
What do you need to know dimensions for? It is a direct fit, no mods. I think there is a sensor on the later models that isnt on the old trannys... I think its the crank angle sensor, but dont quote me on that. Might have to swap your bell housings to keep the one that has the sensor on it.
Check out this before you installhttp://www.240sx.org/faq/artic...y.htm
1991240xs
he meant dimensions for the shipping i think
1dollar240
Quote »... I think its the crank angle sensor[/quote]
WTF!? that wouldnt be on the transmission, its in the distributor, there may be an extra speed sensor on the DOHC transmission, but not a crank angle sensor.
groundhogday1976
I think the sensor problem doesn't apply to S13s, but correct me if I'm wrong.
Queamore
Car: Cars.
Between 100 and 200 depending were it's at and were your at.
wiwalsh
The "crank positioning sensor" is on the transmission (top of bell housing) on s-14s. Not on s-13s. Neglected to see that his was also an s-13.
Dont freak out 1dollar240....
