Will not start
Darius2250
Hi there, I am have an issue with my CA18DET (RWD) not starting my ECU reads 55 no issues there, I have cleaned the AFM, checked all my connections (including the extended wires) I had it running all fin and all was going well, then my BOV started leaking bad, I pulled it and went back to the original piping (eliminating the BOV) at this point the car ran like ***t would barley idle and wouldn't rev at all, I have a SAFC on there and back when it was running the AF% was like .4 .5% now it reads o%. I can hear the fuel pump come on, plus I can smell it. I checked the plugs (they were very wet) checked for spark and made sure the gap was correct (35-40). Right before it stopped I had timed it and it was dead on. Some things I have noticed since it stopped starting/running 1.I smell fuel 2.the rev meter on my SAFC read 300-350 when turning over 3. it turns over but just won't catch.
SAFC settingsSensor type: Hot Wire -7 no deceleration setall other settings are set to the default.
Any ideas and what else I can try?
Thanks
