Will it hurt my M? (Staggered wheels/ tires on AWD)
Danasty13
Car: 2011 m37x v6 awd
Hey guy so my 2011 m37x is awd and i currently have gtr rims on my car we all know that gtr rims come normal in the front and staggered in the back now I'm thinking about getting another set just to have all 4 staggered to make it have that nice flush look now what I want to know is that bad to have on a awd car or as long as the tires are all the same size I should be good thanx
Reason: Edited title
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
You can use the staggered set on your car so long as the tire sizes are close in height and rolling diameter. For example 245/40 on the front and 275/35 on the back works fine. I had 235/40 and 265/35 on my GTRs when I ran a staggered set on my AWD Q70. Never had an issue.
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
Yeah you should be fine with a little bit of stagger; as Don said, provided the rolling diameter is almost the same. There are some good wheel/tire fitment tools in the sticky topics and FAQ's you can play with to try different setups, offsets and tire sizes before buying anything.
Danasty13
DoN_BLaZe34 wrote:
Tue Aug 29, 2017 6:24 am
What if the tires are all the same size is that bad?
Danasty13
wideopn11 wrote:
Tue Aug 29, 2017 6:48 am
Thanx
DoN_BLaZe34
2006 FX45 - Traded
Danasty13 wrote:
Tue Aug 29, 2017 8:14 am
No it isn't bad, I just think it'll look a little funny. If you run 265s or 275s on a 9.5" wheel it'll be a little bulky looking. On the flip if you run a 235 or 245 on a 10.5 it'll be a little stretched.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
I want to see some pics of these wheels on your car!
Danasty13
DoN_BLaZe34 wrote:
Tue Aug 29, 2017 8:42 am
Yea I have 255/35/20 on my gtr rims back is a little stretched
DoN_BLaZe34
2006 FX45 - Traded
What are you running up front?
Danasty13
DoN_BLaZe34 wrote:
Tue Aug 29, 2017 11:15 am
255/35/20 all around
mistayoung
Car: 2013 M37X
I want to run a square GTR rim set up if i run all rears would they stick out past the fenders or should I run fronts? And what tire size should I run?
stm37s
Car: '12 Chrysler 300 SRT8
'11 Infiniti M37 S
'06 Range Rover HSE (Wife's)
'12 Chevy Camaro LS (Wife's)
'95 Chevy Impala SS (sold)
'04 Chevy Impala SS (sold)
'12 Hyundai Veloster (Daughters)
I ant to see some pics as well.
EdBwoy
The GTR rear wheels will most likely stick out. See these 2 links for pictures as well:
1. post6770481.html#p6770313
2. buying-a-diamond-tomorrow-perfect-12-m56s-t620062.html
You should get some guidance on tires in those 2 links, but for something quicker, use a tire calculator such as this one to see their recommendations:
https://www.wheel-size.com/calc/?wheel1 ... m&scl=50mm
Jeime71
Car: 2011 Infiniti M37x AWD
I just brought a set of xxr's 20x9 front and 20x10.5 rear. I'm tryna throw them on my 2011 infiniti m37x awd what tires is best ,tryna stay aggressive but meaty profile. Any ideas ??? Will post pics of them sitting nest to my Appaloosa
DoN_BLaZe34
2006 FX45 - Traded
Jeime71 wrote:
Fri May 21, 2021 6:18 pm
245/40/20 and 275/35/20
Jeime71
What if it's 255/40/20 front an 275/40/20 rear
Jeime71
I'm running that front 245/40/20
Rear 275/35/20 post pics soon
Jeime71
Jeime71
I did a small clip of the look .
Hey the 245/40/20 front an 275/35/20 rear
It's Killin em . Feels aggressive .drives smooth
Feel like when I come through the jungle everything either stand still or moves
They can't stop looking at the car.
Thanks I got BC racing coilovers coming I live in Massachusetts I was thinking a inch and a half in the back 8 in the front drop down and then I got a grill I'm replacing I also want to get a big break kit I was thinking pro street z23 or z26 brake caliper and rotor perforated with the holes any ideas and a air cold intake
bocian320
Car: 2012 M37S (hopefully)
I will be running a staggered setup on my m37x. I went a tad larger with 245/45/20 and 275/40/20. With these sizes, the circumference is 90.1" and 90.0" so nearly identical. I use this site https://tiresize.com/calculator/ it's great tool to compare tire dimensions.
Someone correct me if I'm wrong but I believe the difference between the front and back can be as large as 3% on an awd car. Obviously less is best. 245/40/20 and 275/35/20 is 0.4% difference so that's probably the best way to go. I'm curious how my taller tire setup will look. I'll post some pics when I finally get the wheels.
Jeime71
Was wondering if a 275 40 20 is better than a 265 45 20 on a 2011 Infiniti m37x awd 20s all round looking for meaty look with an inch and a half sticking out in sticking out on the side
kdreger
Ok, I am looking to replace all 4 of our tires on our 2012 M37 with something that will ride smoooooooother! I am fed up with the road noise and rough riding from Contential, Perelli, Yoko. Currently, we have Contents on the cae 245/50 18 inch. If I put 245/60-18 on the car it should give a taller sidewall, thus a better ride I think, please correct me if I am wrong. Also looking at the Falken tires for a smoother ride. IDEAS????
kdreger
kdreger wrote:
Tue Oct 17, 2023 9:31 am
Never mind, that tire is too large.....sorry
