Will Cam timing give no start?????
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
So i put my motor back together and found out it doesn't want to fire up. I have fuel and spark. I did a compression test and found out that the cylinders has 100psi across. I remember timing the teeth but not 100% sure. Before i take apart the motor do you guess think its the timing?
I've replace cap, rotors and plugs. There is spark but doesn't want to start up.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
100 psi sounds pretty low, timing could cause a no start.
JonathanPrem
Yea before i took it apart i had 170psi. I guess i'll check the cam timing
240life
yeah it dont sound like the valves are closing at the right time or fully
LoserCard
Car: Forest Green 1993 240SX SE Fastback
Yeah 100psi is way too low. It sounds like your timing is off. Use this picture to fix yours. It is at TDC with the #1 piston all the way up.
JonathanPrem
So i really messed up somewhere. I took the cam chains off and found out that the intake didn't even spin at all. The sprocket where the pin slides in somehow broke and doesn't move the came.
Do you guys think i might have broken a Valve?
BTW If anyone has s14 intake came please lmk
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Ehh not good, you could be interference on all 4 cylinder. You may want to pull the head and inspect.
Pro ViZion
Car: 1990 Nissan 240SX w/ KA24DE
Before you pull off the head. Turn the engine over by hand a few times and check to see if it stops. If it doesn't want to go any further than you are definately hitting valves. Happened to me lol. Unfortunately.
