NASCARLANCE »
https://forums.nicoclub.com/nascarlance-u25867.html
Fri Oct 10, 2008 12:32 pm
I saw a video once on how to check the distance between a closed hood and the top of your motor. Take any type of modeling clay or Play-Doh and place a cylinder shaped piece on the highest point of the motor where the strut bar would be crossing. Next just shut and latch the hood to compress the clay. Re-open the hood and measure the height of the clay, and this gives you the amount of clearance between your motor and hood.To make it easier to measure/clean-up, place a piece of plastic wrap under and over the clay to keep it from sticking to your motor or hood. This should give you an idea as to whether you could fit a tower brace in there or not.
