Will a 89 radiator work in a 91??
DarkSlide Sil-80
I saw this good deal for a 2 row radiator for a 89 240sx and I was wondering if it would a 91. Thanks!
Queamore
Car: Cars.
It should as long as the drain plug and trans lines are in the same position. But I belive the were the same until 91
nismostate
Car: all sorts of motorsports
this is an old post and im bumping it. would a 89-90 radiator fit in a 91 240 se?
elbles
Car: 1990 Nissan 240SX SE Fastback
I don't think so; my 90 appears to have what would appear to be a KA24DE radiator, and it has problems clearing the hood, so quite a bit of that radiator was dented, and eventually caused a pinhole leak, which is patched until I can find a decent deal on a KA24E radiator for the S13. I'm not sure what kind of problems you could run into in a 91+ model, but I would imagine you'd have similar issues . . . HTH.
Oh, and they are different radiators for a KA24E as opposed to KA24DE, FWIW.
ricebike
2002 Quest
2005 Altima
u can check online for the radiator size/difference via aftermarket manufacturers...
http://www.nissaninfiniticlub....iator
"The radiator we carry for your car is the number 46, but ours is a high efficient core basically takes the place of a 2 row. Our radiator is $89 with shipping and lifetime warranty."
ha, the sales guy doesn't know what he's talking about; 2 rows are betta, just d/t the fact that it'll hold more coolant....
the only difference i saw w/ aftermarkets vs. oem's:full metal casting & usually painted gloss black <for rust prevention on the outside?>, but not aluminum :( <@ least there'll be no leak between the al n plastic tank>
side note: i heard redline's watter wetter is a good addition to your coolin system
