Jberger »
https://forums.nicoclub.com/jberger-u226.html
Mon Jan 19, 2004 5:10 pm
Hey folks,Looking for any insight on a coolant issue from today. This is for Q2 (1991 Q45, 142,000 mi)
This morning, while on the interstate, the coolant gauge began to slowly move lower (towards cool) and over the next 10 miles or so, fell to the bottom mark. I'd been on the road for about 20 minutes, hwy speed, in cold weather (30 f) when the gauge began to drop.
The car is garaged, and appeared to be heating normally, no obvious leaks or burps of coolant. I stopped the car and left it until I could return this evening to check it out after my appointments.
Coolant levels are fine, but the overflow bottle was almost empty. A few drops of coolant around the main coolant filler neck. Added distilled water to the bottle, followed the coolant burp instructions and drove it back home. It took 10-15 minutes for the coolant gauge to show warm and almost 30 minutes for it to reach 1/2 (Normal).
My only ideas are:1) The pressure cap is defective, probably loosing pressure as the system warms.
2) Bad sensor, doubtful but possible.
Ideas?
