Wideband Sensor Placement
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
Which bank on the VH runs the leanest or are they pretty much equal? I want to install my wideband, but I only have one as I'm too much of a tight arse to buy two
tmorgan4
Car: 2000 Nissan Pathfinder
I installed mine on the driver's side manifold last time. This time around, I'm going to install it where it's going to read all 8 cylinders. I've realized that having a wideband on half the cylinders is defeating the point of having a wideband.
Chrispy300
Not really IMO. Sure reading all the exhaust would be better, but with a standard ECU you can't change individual cylinders fueling so it shouldn't matter. Looking at the intake manifold there doesn't appear to be a bank or even a cylinder that would be unequally lean, unlike the VG.
As long as everything is working (injectors) as it should then it won't make a difference between reading 1 cylinder or 8.
Aus450zx
Car: 2+2 300ZX
I agree, if your limited for sensors then you should take the reading from the leanest cylinder. If you read off all 8 then chances are the O2 is placed a fair way from the cylinders, taking longer to heat up and your getting a diluted mix so you could have a cylinder running dangerously lean.
So back to Chris's original question, is there a cylinder that normally gets more airflow?
To take an educated guess I would say the left bank might have a slight advantage because of the angle of the TB, but it would probably be marginal, if at all.
The other option is to do a few runs with it on one bank, then a few runs with it on the other bank, see if one gives a lower reading
Chrispy300 wrote:Not really IMO. Sure reading all the exhaust would be better, but with a standard ECU you can't change individual cylinders fueling so it shouldn't matter. Looking at the intake manifold there doesn't appear to be a bank or even a cylinder that would be unequally lean, unlike the VG.
Return to “VH45DE / VK45DE / VK56DE Forum”
