UltimaSE »
https://forums.nicoclub.com/ultimase-u2604.html
Wed Oct 29, 2003 10:21 pm
One thing that make the techedge and the innovative more attractive is the fact that they use a bosch 5 wire instead of the lt1 5 wire wideband. I was able to pick up the bosch 5 wire from a vw dealer for 28 bucks a few months ago.
So far no problems with the techedge, but I'll admit I haven't had a change to run the techedge against something else for accuracy. JWT did mention over the phone that they'd be curious to see how well it did against their wideband.
I purchased a prebuilt techedge 2.0 wideband kit. Pretty easy to install as well, just get an extra bung wielded in, or you can simulate narrowband o2 off the techedge if you'd like, plug in the wideband run the wiring in, connect everything up and you're done. The hardest part of the install for me was getting the connector through the firewall.
UltimaSE
